Cistern lid
15 Jan 2010
hi all I've got an armatage shanks toilet that keeps running after the flush ( probably seal) however I can't for the life of me get the cistern lid off. It should just lift off but for some reason it seems stuck at the back I can lift the front up a few centimetres and see there's nothing catching it's just seems to be the back edge that's stuck. Anybody any ideas? Tia
A photo would be useful, or at least a description of what style: low level, close coupled etc.
I think it's called sandringham same as this
It doesn't unscrew the push mechanism sits on top of the flushing system like I said I can see inside its just the back of the cistern that won't lift off
It's the same lid as the One in the link. As you will see it should just lift off
The video above is not correct, you need to remove the 2 push buttons then unscrew the centre screw to lift the cistern up.
Andy
Yes it should definitely just lift off, I thought it might be silicone but I’ve give it a good tug and it’s not goin nowhere
That's the thing Andy they don't come out once there in
