Cistern / toilet connection leak
15 May 2006
I have installed a new toilet in my bathroom this week. I now find that there is a gradual drip of water coming from the cistern/toilet bowl join area.
I have seperated the two halves three times now, to check correct seating of the 'rubber close coupling' (Known as doughnut i believe) and still the problem is there.
Even without securing to the floor and wall.
The item is part of a 'Close coupled closet suite' made by Armitage.
Appreciate any advice to fit this without the leak!
Ade
Hi
Is the cistern sat upright on the bowl there by putting equal pressure to the doughnut below?
Hope this helps
Remove the cistern and fill it with water. the most likely place for a leak is where the syphon exits the ceramic
The cistern is as level as I can get it.
Do I use the 'doughnut' without any form of sealant?
OK - separate the cistern from the toilet bowl. You imply that the leak might not be around the 'doughnut' itself but through the plastic syphon fitting - large plastic nut/metal clamp. (Which is brand new)
I'm not sure how I can fill the cistern to check this, as obviously there is now the opening which would match up to the toilet.
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
You stand the cistern on a sheet of paper and fill it with a bucket or bowl, or watering can or anything else that holds water :roll: :roll:
