    Dismiss Notice
Citadal ZR2 problem (Dead / Tamper light) please help
Discussion in 'Alarms, CCTV & Telephones' started by Needy, 10 Aug 2019.
  1. Needy
    Needy
    16 Jan 2009
    110
    Thanks Received:
    Gwent
    Country:
    Hi All
    WE have a Citadal ZR2 house alarm that has gone faulty
    I changed the back up battery and disconnected a 12v cable to one of the PIR's that had gone faulty and is no longer used (always had to omit it ) and its in a room now with no access (Bathroom) and now we have a dead keyboard with a solid tamper light on?
    Anyone know what the problem is or how I can get around it
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    8,895
    Thanks Received:
    1,351
    Sheffield
    Country:
    In other words an optima ...
    The keypad will be dead until the tamper fault is sorted ...or press reset ..
  4. Needy
    Needy
    16 Jan 2009
    110
    Thanks Received:
    Gwent
    Country:
    reset on the keypad wont work any other ideas
    thanks
  5. sparkymarka
    sparkymarka
    16 Feb 2011
    8,895
    Thanks Received:
    1,351
    Sheffield
    Country:
    Sort out tamper fault you have caused ...by probably disconnecting that cable !
  6. Needy
    Needy
    16 Jan 2009
    110
    Thanks Received:
    Gwent
    Country:
    tried that and nothing still the same
  7. Sponsored Links
  8. sparkymarka
    sparkymarka
    16 Feb 2011
    8,895
    Thanks Received:
    1,351
    Sheffield
    Country:
    How did you disconnect it ? ...what did you remove ...where ?
  9. Needy
    Needy
    16 Jan 2009
    110
    Thanks Received:
    Gwent
    Country:
    the pir in question the led was always on so when we set it we omit that pir, so when I changed the battery as it was knackered I tracked the 12v cable to that problem pir and disconnected it (led light went off) I was hoping that would disable that pir altogether
    thanks for trying to help me out
  10. sparkymarka
    sparkymarka
    16 Feb 2011
    8,895
    Thanks Received:
    1,351
    Sheffield
    Country:
    ....what did you disconnect ? How many wires ? Where at the control panel or detector?
  11. Needy
    Needy
    16 Jan 2009
    110
    Thanks Received:
    Gwent
    Country:
    just the red 12v wire to turn off the led (1 wire) both ends panel and pir
  12. sparkymarka
    sparkymarka
    16 Feb 2011
    8,895
    Thanks Received:
    1,351
    Sheffield
    Country:
    So either A the panel lid is not on correctly
    Or the detector lid is not on correctly
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
