Cladding a block shed
18 Feb 2006
Birmingham
Hi all
I have a single block shed which I am thinking of cladding in waney edge board. I wanted to know before fitting the battens should I wrap the shed in membrane first or should I just clad it straight onto the blocks?
many thanks
Meant to be: breathable membrane, then battens... also an insect mesh at the bottom.
Are you doing this purely for cosmetic reasons, or for performance?
look at cembrit or hardie plank. Much nicer than waney edge.
Hi all
many thanks
breathable membrane, then 50 x 25 batten at say 600 centres.
if you have a side of the shed that faces the fence or end of garden, then you could clad that with cement board - saves using timber cladding on sides that aren’t seen and avoids any maintenance.
Many thanks. Think I’ll just glad the whole lot even though 2 sides won’t be seen.
Thanks for the option. I need to look into costs and other timber options. Want it to look like a timber shed. A t&g style would be good if available in fibre cement
With costs of timber and the time it would take me I am also considering render and paint
You don't need a membrane on masonry! Its for timber frames to allow the frame to breathe.
As long as the cladding has a drained cavity behind it, then it will act as a rainscreen and prevent the wall becoming damp.
Cedral or similar cement board timber-effect cladding is relatively cheap nowadays and no maintenance either. Some it it is about £3.50 /m, which is a bit more than SW, but a lot less than plastic or the silly prices of hardwood
