Hi Guys
Can you please clarify the position as far as cables buried in either block or partition walls and mechanical protection. I have searched through the forum but have found some conflicting info.
Scenario1:
13A ring sockets (2.5mm T&E), 13A Fused spurs(2.5mm T&E), 5A lighting switch or Oven/Hob cable(6mm T&E) put into channels running vertically down from the ceiling to each connection plate, walls are soft breezeblock. Circuit may run horizontally from socket to socket.
Wall then covered in dot'n'dab plasterboard and skimmed.
Scenario2:
Standard 75mm or 100mm stud wall with plasterboard and skim. 13A ring sockets (2.5mm T&E) or 5A lighting switches
Scenario1:
Scenario2:
