I am in the process of having a conservatory built and would like to lay wiring before the walls are plastered next week. I plan on laying the cable and then getting an electrician to wire it up. The problem I have is knowing the format to lay the cable.
What I want in there is two double sockets and a remote controlled fan light - so after reading some info on here (thanks guys) was thinking of doing the following
Ring socket --2.5mm t+e--- 13A FSU/FCU---2.5mm t+e--Double spurred socket----2.5mm t+e---Double Spurred socket ---- 5A FSU/FCU ----1.5mm t+e -----Fan light
Is this an OK configuration? Or should I be laying the cable in another configuration?
