I have the above boiler which has worked without issue until a couple of days ago when we started noticing a drop in water temp.
Upon inspection tonight noticed the pilot had gone out but when the water heating was switched on the fan kicked in and a clicking could be heard..I assume the pilot trying to relight.
I have followed the manual for about half hour repeating the same process, eventually getting it lit, now it has gone out again after about 10 mins.
The only thing I have noticed is there is reference to an overheat thermostat switch located on the right of the cpanel and to press this when the pilot goes out, this i understand in the manual should be "proud" if activated so you can "press" it, however it looks and feels like it is jammed - there is no movement in it at all to push in (although the switch housing feels loose..if that makes sense?..its a red colour with a cross on its head) and it sits semi flush with its housing...not sure if related but any ideas?
