Clay double Roman shallow pitch headlap
20 Jan 2014
Avon
Building a single storey extension using existing and reclaimed clay Double Roman tiles.
A canopy goes over the main door. it is about 1500mm deep and 3000mm wide.
It as a shallow pitch of 17 degrees what headlap is recommended?
The main roof is trussed and has 30 degree pitch and the canopy comes off this.
which Double Roman are you using?
17 is near the mark for most with a headlap of 100mm
double check your pitch.
Marley double romans will go down to 22.5 degrees with 100mm headlap. This only applies to the smooth fellas.
