Cleaning off recent residue wallpaper paste from walls before painting?
15 May 2016
Hi all,
I papered my room with lining paper, then decided to take it all down and prepare to paint straight onto the walls. I did give the walls a wipe down with cold soapy water and when that dried I gave them a coat of watered down PVA. Once the PVA had dried I filled in areas of the wall and sanded the walls down. Though on a second cleaning I can still feel a slimy residue when wet.
Just wondering what the best ways to get the paste off are? I've been reading hot water is good along with a separate bucket of soapy water to clean. Should I still give it a coat of watered PVA afterwards just to be safe? Cheers
Major error with the PVA:
//www.diynot.com/diy/threads/mist-coat-or-pva-bare-surface-basics.425261/
You could have saved yourself a lot of work, and any potential issues, by using Zinsser Gardz to seal in the old paste residue. The product is designed for that job and gives a perfectly sealed and stable surface to paint directly onto. It my still be a good idea to use it on top of the PVA, although when I contacted Zinsser about using it for that job, they couldn't guarantee it would be successful.
http://www.zinsseruk.com/product/gardz/
Should have sugar soaped after removing the paper, and scraped as much of the glue off as possible with 2 washing downs with the sugar soap. Then a coat of Guardz and then paint.
Now you have a bit of a situation with no guaranteed solution except sanding all the PVA off, or re-skimming
Zinsser Gardz and carry on. I don't think the pva will be an issue if you coat it it with this.
Cheers guys, yeah feel a bit gutted putting all that PVA on now :( I think my best bet is to give the walls a good sanding and a coat of Zinsser Gardz
