Clearing a 25mm MDPE Blue Water Pipe
9 Feb 2016
Does anyone have any tips on how to clean a buried 25mm MDPE Blue Water Pipe. Its approx 80m long - its a cold water supply from a spring and peat lines the inside of the pipe after a few years. It has a drop of about 10m from the spring and I have the facility to blast water through it at 3 Bar back from the house to the spring but the flow rate is still very poor. I have thought about 'pigging' it with a ball bearing but worried I might get it stuck - any ideas
thanks
Jim C
14 Nov 2007
Buckinghamshire
Check if there is stopvalve, gate valve or lever valve isn't clogged.
At 3 bars, that is fine, but you need to put more flow in it to clear it.
Pigging with a ball bearing might be a good idea but risk getting stuck. You will need a strong air pressure to push it all the way to the end. 80 metres long, wow.
At 10 metres, that will give you about 1 bar pressure which with 25mm size will give you slight poor flow.
Daniel.
N
Newboy
Something like a drain snake (new of course) might do the trick - might be difficult to find one with a full 10m reach - are both ends of the pipe accessible?
The business end might need to be trimmed down to fit the MDPE bore
26 Jun 2004
London
Why are you two talking about 10 m ?
He says its 80 m long!
N
Newboy
Eyesight must be failing - I could have sworn that when I read that post it said 10m!
