I live in a 2 up 2 down end terrace house. The heating is fine apart from the living room where we have to have some form of supplementary heating on cold nights. This rooms side wall is north facing. The walls are solid, that is no cavity, and consequently quite cold. If I set the stat in the dining room to 24 degrees the living room just about keeps up to temperature but the dining room is unbearably hot! All rads have thermostatic valves (wide open)
Any ideas on how to improve the situation?
Should I swap the single panel rad in that room for a double? If I set the thermostatic valve in the dining room a bit lower the whole house warms up to some degree but the boiler never cuts out on the room stat......
H
H
