I have tried everything to fix a single cold radiator which has never worked since I moved in
Changed the rad, the TRVs, removed some isolating valves I found on the spur. There is flow to the rad ( the flow pipe gets hot), there is flow on the return ( the system drains successfully through a drain on the return flow of this rad ). No airlock.
If I turn all other rads off, then it will eventually get warm, but not hot like the other rads on the system. The return pipe never gets hot.
I am wondering now if this is just bad layout . It is one of 4 rads added in an extension. The spur that feeds the radiator ( the only one on this spur), is 10 m, each way, and must have 6 x 90 degree turns on each flow. The final stretch of the return goes from ground floor to first floor. At least part of the spur is under concrete.
I just wonder if there is not enough pressure to push water round this convoluted path, through a 2000mm x 600mm double rad, and then back again.
Any thoughts ?
Any thoughts ?
