cold radiators in a flat
31 Oct 2005
Oxfordshire
My brother altered some pipework to one of the radiators in my flat as he has done other times in other properties. The central heating was working intermittently afterwards but lots of air in the system. I have tried bleeding the system a few times now and also refilling via the drain cock. I am 99% sure that the pump is working and also the three way valve. The hot water isn't affected and is good. There seems to be some water gurgling back down the pipe near the hot water tank if I switch on the heating. I can hear the pump trying to force the water around and then when I switch the heating off again I can hear the water running back over. I think it is something simple that I am missing. Could someone lead me through step by step to putting this right please?
Not obvious.
COuld be a pump speed thing - ask if he altered it. Or try on speed 1 (usually out of 3) and see if that shuts it up. If rads not all working increase to 2...
Have tried this but still radiators will not heat up. I can still hear the pump working but no heat in the rads at all!
