Hi all
I have a Combi 24 HE boiler that is leaking from the refill inlet - both at the mains end and the boiler end. It is a very slow drip from both ends, but the boiler end leak means that the boiler keeps losing pressure and needs frequent refilling.
As you'll see in the picture, there is no tap on the mains end - to refill I have to use pliers to turn the bolt to start the flow. To stop, I have to put it in precisely the right position - i.e. if I turn either clockwise or counter-clockwise from 90 degrees the water will start flowing - I have tried turning this small amounts but I still get a small drip.
There are two black taps (pictured) and also some other taps below (also pictured) but I am not sure if I should be turning anything else off once it has been refilled. Hope that makes sense, happy to post additional pictures if helpful.
Many thanks in advance for the help!
Seth
Seth
