Hi Guys
I,m looking for a bit of advice from the peeps in the know, hopefully the community will be able to point me in the right direction, I've tried searching but cant seem to find a conclusive answer to my question.
I moved into a small cottage in a rural part of Scotland August last year, the property is pretty much off grid so the heating and water are electric.
I,m looking at doing a long term change and in phases as finance allows, firstly I need to work with the hot water side of the system as the current tank fitted which is unvented uses two electric immersion heaters to provide the hot water, when the girlfriend visits with her youngest daughter, the daughter gets in the shower she seems to go through the 200l of water the tank provides which leaves everybody else waiting for water until the tank heats up again. We have one bathroom with, mixer shower, bath and one sink, the kitchen has one sink and we have a on suite with a sink and again mixer shower. Normally only one shower is used at any one time so demand is not a huge factor across all of the taps / showers
My first question is....
With us being off grid I,d like to fit a combi boiler running on LPG along with keeping the unvented tank with immersion heaters in for emergencies should we run out of gas, the current setup looks pretty standard and has the tank with mains water feed direct into it, this is then fed off to the various taps / showers in the cottage, Firstly, is it feasible to T off the cold water feed before the tank and pipe it into the combi boiler, then the DHW from the combi boiler is piped into the output side of the tank via a 3 way motorised diversion valve, the diversion valve is operated by the feed to the immersion heaters so when the heaters are on the DHW from the tank is usable, but when the immersion heaters are off the Combi boiler provides DHW on demand. Is this a feasible solution ?
Question 2, with the system being installed over time, the heating side of things will evolve as and when funds allow, in the meantime.... is it possible to pipe in the boiler too heating distribution manifolds which are blanked off, have a pressure bypass pipe installed and pressurise the system so there are no faults on the boiler, then keep the heating turned off until one or two radiators are fitted and expand the system from there, again is this a possible solution or even feasible.
I don't want to have to buy two different boilers as the system evolves and as such would greatly appreciate any advice good or bad along with suggestions.
Thanks in advance.
Thanks in advance.
