- Joined
- 31 Dec 2003
- Messages
- 188
- Reaction score
- 4
- Country
My Boulter Bouderas (now Worcester Bosch I think) combi boiler is normally pressurised to 1.5 bar. Over the last month it has lost 0.1 bar. Is this cause for concern or should I expect a small loss?
I have a heated towel rail in a bathroom that was getting air in it so I fitted an automatic bleed valve which has solved that problem but I guess there could be a leak somewhere causing this? The towel rail is much taller than all the standard rads and is the last in the line - don't know if that is significant.
A short while ago I moved a radiator in a bedroom and for the first time I used plastic push fit pipe. I didn't push it fully home the first time (didn't realise how hard you have to push) so got a real flood but I re-did all the joints and checked and re-checked and there was no evidence of any leaks.
There was a small seepage on another rad valve joint so I tightened it up and seem to have fixed it.
There is no obvious sign of leaks anywhere.
Thanks for any advice.
