Yesterday, following an annual inspection, a BG man hung a notice on my mother's combi boiler saying "... in the interests of safety do not use until any faults have been remedied." The "fault" in question appears to be that the pipe from the pressure relief valve is routed upwards into the loft space above the boiler before (I assume) it goes outside somewhere. The boiler was installed in 2007 and was inspected a year ago without fault. I could not find anything in the Worcester installation guide from 2007 regarding the routing of the PR pipe although there is a mention in the 2010 guide. The general advice seems to be that the PR pipe should be routed downwards from the boiler to terminate somewhere safely. Is the fact that the pipe goes upwards sufficient justification to hang a sign on the boiler to say that "it should NOT be used". I think that any warning, if warranted, should be couched in terms of saying that it is not in accordance with current or good practice and that it would be ADVISABLE to make changes. Has the guidance changed since 2007 or are some inspectors being far too cautious in hanging a scary sign on a boiler that doesn't need one?
