- Joined
- 19 Jan 2008
- Messages
- 15
- Reaction score
- 0
- Country
Hi all hope your all well and have had a good weekend.
I have a major problem with my boiler i have a glowworm 100e the main prolem is it cutting out. The lock out light does not come on but the boiler doesn't work. This seems to be a intermitant problem.
The boiler at first seems to work fine and then all of a sudden stops no heat or water if you then leave the boiler a while and then switch it of and then back on it works again for awhile. at the weekend the removed the heating thermister and cleaned the sensor and ensured the wires where all connected correctly and the boiler worked thursday till sunday evening with no problems then all of a sudden it started with it's problems again. I personal can't see the thermister causing this problem but please i'm open to being proved wrong. I possible think the cut off sensor could cause this problem but not sure. Any advise would be helpful
Many Thanks
Dan
Many Thanks
Dan
