Combi shower going Hot-Cold-Hot problem
I retrieved all the bits except one small leg on the valve. Just couldn't find it. All working as it should now.
Could be that the bit you couldnt find is trapped in the plate heat exchanger and causing the noise
Thanks Ian. I think that if I'm going that far I may as well buy a new plate heat exchanger and fit it. May be lucky and find it behind the venturi valve. You never know.
Steve
