Combi: Simple as ABC really
11 Jan 2009
Good evening
Previously posted about quality of combi instalation and was slaughtered by the British Plumbers Federation so I'll tread carefully now!
Seriously it was a good job and I'm happy, but..
The guy was a one man band and is now in hospital so I would very much appreciate your expertise on simple questions that I can't answer from the manual.
The combi is Worcester Greenstar 30 CDI.
1. There is a programming dial but I don't know how to set it. Can anyone help?
2. When you prog the boiler is it the equivalent of switching it off and on or does it stay on and just ignite the boiler at the appointed time?
3. Either way if you prog the boiler does the heating temp depend on the room thermostat/boiler thermostat?
4. I was originally told that I could only prog heating with this boiler. Does this mean that there will be no hot water during the programme times?
5. Can someone explain the relationship between the room thermostat and the dial in the boiler itself (I note that the boiler temp as indicated is usually different to the room thermostat temp)
6. In essence are the new thermostatic valves on the radiators a waste of space or do they have a function?
Sorry to be painfully obvious but short of visiting the poor guy in hospital I'm floundering a bit.
Many thanks
L
Try User Guide as I assume its the internal one, try WB web site if you have not got one
Shockingly, it turns the heating on, depending upon the RS temp
Ultimately the Boiler stat. The rads will not get hotter than the temp of the water coming out of the boiler. Although you done want the room to be hot either
Its a combi, HW is on demand 24/7. The program times for HW are possibly for pre-heat.
They have a function
If you do go to see him take him some grapes
