Combi system valve change
4 Jan 2006
Yorkshire
Big cast iron rads removed to restore parquet flooring and on re installation son wants trv's instead of manual valves.
No access to sub floor to see if there's a drain cock so I guess I will have to rig up a hose to the manual valves individually to drain down before replacement.
Not worked on a combi system before but I gather its just a case of turning off the power to the boiler,draining down then on refilling opening up the valve on the filling loop and vlosing at the recommended pressure. The boilers a valiant around 12 years old, any ideas what the should the pressure be once the system is bled.
Tia.
Yes, on a combi, you can often create a vacuum once drained. Pressure should be 1-2 bar maximum.
