Good grief.
Jog on Alex.... or is it Big Burner? Dr Drivel? whatever....
Which was bo11ocks !! (his terminology) I just looked up the boiler specifications. The boiler can go as low as 12.3 kilowatts. It is perfectly suitable for a 5 bedroom house. This boiler is perfectly suitable for a house like that. Use a low loss header and it will have a constant flow through the boiler at all times.I'd take Dans advice.
To the OP please use some common sense and not go by off the cuff comments by someone who may be on the wind up. Your boiler can go as low as 12.3 kilowatts which is about right for your house. You can ditch a perfectly good boiler if you like. That is your choice as it is your money. I would keep it as you got a new boiler for peanuts.
Vaillant may call it commercial - I don't know why, but probably to hype up the selling price. Gasafe say only those over 70 kilowatts are commercial.
http://www.vaillantcommercial.co.uk/products/ecotec-46-65-kw-output-wall-hung-condensing-boilers/
Someone was one about a large buffer to absorb the full 43 kilowatts. Isn't that a thermal store? That would replace the planned unvented cylinder.
Have you been on the whiskey?Good grief.
You have been on the whiskey or taking the pee out of the OP. The boiler can give 18 kilowatts. It can give 46 if you like. But it will NOT sit there switching on and off giving out 46kW as it can go down to 12.You would have to be mentally deficient to install a boiler that had a MINIMUM output of 12kW in a house that probably has a maximum heat requirement of 18kW or so.
The boiler can go down to 12 kilowatts. He will not be using 46 kilowatts.sell it on ebay, you could probably get more for that then what you can pay for a correctly sized equally used boiler
He can fit a low loss header with good insulation and maybe have a pipe thermostat in it to keep it from cycling (which it probably will not and the temperature stable - need to speak to makers on that or look in instructions).You have to remember that for most of the year you may only need several KW.
You are on the wind up for sure.Have you any idea about Heatloss calculations?
He can fit a low loss header with good insulation and maybe have a pipe thermostat in it to keep it from cycling (which it probably will not and the temperature stable - need to speak to makers on that or lo0ok in instructions).
I would keep it.
