Completely Open Circuit On Switch Cable
11 Jan 2004
Concluded some fault-finding today.
The kitchen lighting flickered then went out with a bang. The other day, I went to the switch & could not find anything there. So I went round all fittings to see if I could find anything. Nope. All I could see on the kitchen downlighters were switched feeds.
So I returned today after the customer made access through the plasterboard (laminate upstairs, don't you know!)
I found several chock blocks not enclosed. All OK there, although it stank of an amateur installation, with a mix of grey 1.0 and white 2.5.
Then the customer extended the hole. This exposed a whole nest of connectors that were obviously the site of a disused fitting. These were sandwiched between a bearer & the plasterboard.
Then I found a JB with three cables attached, one just cut off. Dead, but why don't people take this stuff out? Ditto an old immersion switch fed via VIR.
Then I looked at the switch cable at the switch position. It was set in a stud wall. I removed the dry-lining box & got my maglite in the cavity. The cable went down and across. I could just see it was trapped between the plasteboard & the studding...
I then followed the switch cable from the other end back towards the switch. I found yet more joints in cables, this time twisted & taped (no blocks). The whole job was utter pants. Even two downlighters had been cut out of plasterboard actually overlapping the joist so it cut a semi-circle out of the timber...
This job supposedly overseen and signed off by the local BCO.
Anyhow, eventually, I found the cause of the O/C switch cable: :shock:
Sorry guys...I've now rotaty'd the piccy. But yes, you're right.
Send a report with photos to:
1) Your councillor (assuming you live in the same jurisdiction).
2) The Borough Solicitor and the District Auditor, accompanied by an allegation of fraud by Building Control.
3) Local media.
Basically be a seagull.
