I've re-plumbed all the cold water this weekend. Following a nerve wracking "turn on" from the pavement stock valve I was VERY relieved to find only one tiny problem.
The compression joint on one side of the stopcock is weeping very slightly. I placed a rag round it to "quantify" the loss and this is one small weep indeed.
What's the bet solution for rectificying it? A bit more tightening on the nut? Obviously I do not want to run into overtightening problems! Or can I apply jointing compound or the like to seal it?
I have heard about compression fitting "weeps" healing themselves. Does this work the other way - i.e. can they get worse too?
Any advice appreciated.
