Hello all,
Quick one [!!]
Replacing rad in bathroom. New rad is different size. Will therefore need to drop the tails from the new rad and then connect under the floor boards to the existing rad pipes. The existing floorboards will be covered with a floating floor so that I can still access the pipework underneath should anything go wrong.
Anyhow, as I see it there are 3 options;
(1) Use a compression elbow from each of the rad tails joined to a right-angled bent pipe then straight compression joints to the existing two pipes.
(2) Use a pushfit elbow from each of the rad tails then plastic pipe to pushfit straights joining to the existing pipework
(3) Same as (1) but using plastic pipe with inserts joining the two 'new' compression joints.
Reason I ask is that I always feel that compression joints are 'safer' than the plastic ones but I have never used compression joints with plastic pipe and using plastic pipe makes the pipe run easier to sort. The easiest would be option (2) but I would appreciate your views on how 'safe' this arrangement is.
By the way, I suspect the professionals on here will say that the best method is solder fittings............
Many Thanks
Quick one [!!]
Many Thanks
