Hi - I have the vanity unit - should I fit the cistern on the wall below the top bar at the back of the vanity unit?
There is a mounting bracket with the cistern - it's a plastic bracket and I am uncertain if this alone would support the cistern weight when filled with water? Should I install some sort of bracket at bottom of cistern to give additional support?
Where's the best place to put the push flush unit, top of vanity unit or at front of it?
The floor where the vanity unit is to be installed on is not level (!) - the wall should be level, should I screw the unit to the wall and fit about 10mm wood strip under the front to support the unit? I am not keen to scribe some it off as there is a full base at the bottom which would need relocated up.
Lastly - how should I cut the vanity unit to fit the BTW WC - rectangular hole to allow the two fitting pipes access?
Hope thats the last of the questions
