Concealed hinges
18 Jan 2006
Cumbria
I have recently had some new doors fitted to my under stair cupboard. I asked for concealed hinges but they fitted normal ones. I was not happy with the work in general so won't be getting them back and will do them myself. Question is, how is it best to conceal hinges? I was considering recessing them in the door edge with the recess stopping short of the door front. Are there better options? The doors are hollow so not suitable for kitchen cabinet hinges. The doors are hinged so that they open wardrobe style with no central post. Any help appreciated.
New doors , they are not suitable for what you require which is also why they have normal hinges fitted.
Although I say hollow, they are fairly substantial, consisting of a 25mm square frame (with internal cross braces) faced both sides with 5mm ply. I can't see how these are any different to a solid door as far as hinges are concerned. That is another reason I don't think kitchen cabinet hinges would be suitable, the doors are quite heavy and wide.
Sosa hinges are great if you know how to use a router!
My mistake as you not wanting to see the hinges but flush hinges would work best as they have a very small knuckle! The problem you have is that they are egg cup construction so any decent concealed hinge would require you fixing in the back which may miss the guts of the edge of the door. And over time just give and wear. Hope this helps
