Concrete Expansion Joints
22 Mar 2006
Yorkshire
Hi All
Back again for advice. I am preparing ground to lay concrete. The area is 5 meters X 6 meters X 100mm deep on a 100mm hardcore bed impregnated with weld mesh. I am planning to use this area to park 2 cars on it.
This is huge area to lay concrete in one go therefore I am planning to lay in three segments. The concrete laid will be ready mixed. Having concrete in my drive both sides are not sealed this is a menace for weeds in spring/summer.
Is there a method of sealing the joints and allowing movement. I believe they used to pour bitumen compound in the joints in the olden days. Is this still done or something different is used. Positive advice will be appreciated.
:LOL: :LOL:
Sorry but I find this quite funny.
My brother is a concrete laying contractor. A huge area to him is 50mx30m requiring 500 cubic meters and he has done a few of these in a single day with no expansion joints. (4 men!)
But if you really think you need to lay this small amount in three sections then I can give you the name of the product he uses to seal contraction/expansion joints if you wish.
You will also pay quite a high price for "part load" readymix plus you don't want the embarrassment of the delivery driver laughing at you either. ;)
So what were these 300mm thick slabs?
Has your bro returned 1,3, 5 years later to check that no movement or contraction has occurred?
To the OP, you are better off laying this in two bays - with the joint running up the drive. You probably don't need a movement joint, nor expansion joint but you will just form a construction joint - which is just a joint in a natural break in the work.
You wont need to seal it if you pour the new bay tight up against the previous one. A sheet of polythene or DPC can help as a slip plane, but the two bays are best tied together with reinforcement
:LOL: :LOL:
It may be funny to you my friend. I am doing it by myself. I started digging last friday and believe you me I have dug 1/3rd of the area so far. The ground is clay impregnated with rubble. It is painful. Your brother having four men with him and probably a small digger. laying 500 cu meters concrete with men power and machine is achievable.
All of my neighbours have passed comments that I am extremely brave to take on a huge task by myself. So if concrete delivery driver wants to laugh at me he might get a shock to see how I have single handed dug and prepared the ground all by hand.
Hi woody
what is a bay tight.
