in the kitchen we have an old fireplace - in front of the fireplace the old cement hearth has been taken out (the one in our living room is plush with the floorboards and i assume that the actual hearth was built on top of this 'cement' base?).
This base has been replaced with chip board some time in the past.
here's the hard part - how would i re-instate just concrete hearth base (aprox. 33cm x 114cm) so it's plush with the floorboards (18mm thick) but still strong enough to be walked on and not crack. (the joists are all present and correct - SIR!)
the only thing i can think of is fitting some sheet metal (1 or 2mm thick) and then applying a cement 'base' on top of it but is there an easier way?
how was it originally done?
anyone any other ideas??
ta vary muchly
ta vary muchly
