I'm renovating an old 2 up 2 down terrace house and need to replace the downstairs timber floor. An old extension on the back blocked the rear bricks (this is going to be replaced) and as such under the floor the mud is damp and wet causing the old floorboards and joists to rot.
A builder has quoted to lay 100 mm of hardcore, followed by sand, membrane, and then 100 mm of concrete on the mud. Then rebuild the sleeper walls, new joists with insulation and then chipboard.
My question is if the concrete slab is required? Surely what is important is the membrane so can't this be placed without the concrete and hardcore?
The mud is about 500 mm below the floor level. Total ground floor area is about 28 m2, quoted cost of work is £ 3400 + VAT. Do people think this cost if fair?
Thanks for your help,
Chris
Chris
