So I have nearly finished laying the floor for my garden workshop.
The concrete that was laid this morning is a little soft on the surface - scratch at it and it is loose. When I laid this to get it the correct height I did move it a lot and there was a lot of water on the surface. I have read that this could have caused a weak surface and if sprayed with water and left it may cure off?
I have just sprayed it with water and will leave it for another day and see what happens.
If it cures OK what do you guys n girls suggest to finish it off should I use some sort of a leveling compound or mix up a scree coat if so what would the mix be. I would like a smooth ish surface that I may paint with and epoxy paint (Grey).
