I'm rendering a wall with a concrete and hydralime mix plus concreting in a lintel above a garage door - the lintel sits on top of a concrete block wall.
The problems are the lintel got knocked (upwards) by the door - didn't think I hit it that hard and it seperated the lintel from the wall. I'm thinking the concrete was not so strong...
Also I rendered a wall and when drilling a hole quite a bit of conncrete/render flaked off. Again I'm thinking it's not very strong.
Some causes may be:
Lintel and the top of the wall were not PVA'd before concreting - should they be, will it make a stronger join?
The wall was done on Saturday and due to the weather dried quick and on Sunday I drilled it, is that too soon? Also maybe the weather dried it too quick?
The concrete seems to have partially set in the bag i.e. it's not a fine powder but I have to scrape it with a trowell to get it into a powder - has the concrete expired?
I'm using hydralime (and less concrete) in the mixes - on the bag it says 'improved performance' but maybe it's not as strong. I'm also using the 'strong' recipe on the bag so am expectign it to be as hard as ummm concrete.
Some causes may be:
