Concreting in 0 degrees
5 Dec 2012
Ideally I want to concrete in my aco drain and last remaining flat top concrete edges today (for patio)
Weather says temp will be 0 degree lowest but 7-8 during day.
Is it ok to concrete in these conditions?
Cover it up with something insulating at night, it'll be fine. Curing times are extended in low temperatures
I normally use an old duvet, between plastic if it looks like it's gonna get wet
Surfaces can get spoiled, is about all. If its a big lump, I'd not worry too much. Throw some hessian sacking over it or a few old dust sheets.
You can use warm water in the mix, which helps, and cover it once set enough not to be marked. It will lose a lot of heat on a cold, clear night if not covered.
Warm water does not help.
What may help, as the cement reaction is exothermic, would be adding more cement.
But easier would be to just add an accelerant/ frostproofer.
Why do you say that? It is done in cold regions.
I say it because it does not work, whether it's so cold that 0°C is within the hour and then all night, or whether 0°C is several hours away.
Think about it.
And then add the fact that the water in the mix must have reacted or evaporated before it is allowed to freeze
