Hi earlier this year I had a Worcester 37CDI boiler fitted.I believe I am getting condensate discharge from the flue.This can be one drip every 20 seconds or so or more often than this or not at all - presumably depending on ambient temperature in the house and demand on the boiler.
The boiler is installed on the wall in the garage adjacent to the external wall.The flue run is very short to the single cavity wall about 300mm.External there is about 150mm to the end of the flue.The flue is horizontal and I believe that because of the short run this may be causing the discharge?
Does the flue need extending?
Or two 90 degree bends fitting?
Just wanted some advice before I tackled the installer as still under warranty.Have a heat trace insulated condensate discharge pipe fitted and seems a shame not to use it!
Thanks in advance
David
Thanks in advance
David
