Hi, I have an existing combi installation with the condensate drain going out the front of the property through garage wall which then goes underground and into a drain about 1.5mtrs away.
I want to put in a new block pave drive and have no need for the drain to be there - is it possible to cap it off permanently (leaving the cond drain pipe connected) and bury beneath the block work, or should I leave access to it?
I’ve also considered running the drain pipe out of the rear of the garage and into a McAlpine type soakaway device, but the pipe run will just exceed the 3m limit, and I’d need to bury the device below ground along with the drain pipe - is that permissible?
Many thanks for any answers or advice.
