Condensate drainage in winter
3 Nov 2006
Bedfordshire
The problem is the location of the boiler requires a long run of drain for the condensate in order to reach the nearest acceptable drain. At least 2 metres will be external. Longer it internal works are to be avoided.
Proposed solution. Comments please, Run the condensate drain pipe inside another pipe. Using a small fan warm air from inside the house will be blown along inside this outer pipe to keep the condensate pipe above freezing point.
The proposed fan is the type used to cool computor power supply units, 4 inch square 12 watt or similar.
Theory suggests that the small fan could be supplied from the switched supply to the CH pump ( heat only, not a combi ) to ensure the fan runs only when needed.
It is a new installation in a listed building where the acceptable flue terminal locations restrict the location of the boiler to the "un-seen" side of the building where there is no drainage.
Trace heating is one option,
Routing through the building would mean crossing a hall way about a foot above floor level.
Not a plumber or even a decent DIY sort of person but when i had my boiler replaced the new boiler was placed where the old hot water tank was due to no space where the previous boiler was situated.
The Condensate tube for this is just ran straight down the outside wall (with a bit of insulating foam around it) to some sort of pit buried in the ground.
Now i'm starting to wonder just want the plumber has done lol
Just looked this up.
Its a soak away hes put in tho not sure about the distance he put it from the house but guess i gotta trust him lol.
anyhow, with the last 2 bad winters never had a problem with the condensate freezing in the down pipe.
Maybe this would be a better soloution for you?
this was done for me as oddly enough my house has a entirely internal drainage system (except as small combined drain at the front for my and my neighbours guttering) and the boiler was no where near the main drain downpipe.
I thought at first this was someone taking the Micky :D
I can't fathom why your installer cannot find an acceptable route for the condensate to discharge into
Install a condensate pump and discharge it into an internal waste system in the house
Simples :rolleyes:
2m external will be fine in 1 1/2" from inside to out. Or as said pump it.
The method being adopted is to use an ELV ( 12 volt ) PTFE insulated nichrome trace heating wire inside the pipe.
