- Joined
- 18 Feb 2007
- Messages
- 1,359
- Reaction score
- 76
- Country
I have just had an unvented CH system boiler replaced. The new boiler is a Vaillant 430.
This new boiler required a new condensate drain installing as the previous Glow Worm Boiler did not require a condensate drain. The installer, quite rightly, piped the condensed drain into a storm drain Down pipe which is located about 4 metres away from where the condensate pipe emerged from the wall. The only problem I have with this is that the resulting sloping Pipe which is insulated, is very unsightly. The wall along which it traverses has a gravelled path at the bottom of the wall. If the condensate pipe was repositioned to be a Vertical drop down to this gravelled area it would be much less unsightly, then I think the amount of condensate generated by the boiler will be so small it would be easily dispersed in this gravelled area.
Has anyone any advice with regard to this suggestion.
