my condensate is leaking from where the pipe connects to the trap. is it possible to put some sealant arount it as temp measure until i get plumber in? if so what can i use? many thanks
I wouldn't makes it even more difficult to repair when you gotta try and peel it all off. Most are sealed with rubber washer and even hand tight is sufficient.
