Would appreciate some advice please....
A friend has been complaining about drain smells in the kitchen. When I had a look under the kitchen sink, I found that the condensate pipe and the PRV outlet from the boiler terminate above a vertical HepV0 valve with a funnel stuck in the top! The reason for the smell is obvious, as the rubber component inside the HepV0 no longer seals, and the pipework from this valve joins the sink waste pipework after the sink trap.
So firstly, could somebody tell me if this set-up is contravening any regulations, and secondly is the acidic nature of the condensate likely to have caused the HepV0 seal to fail?
Basically, I'm wondering whether I should simply replace the duff HepV0 with a new one. I could alternatively make a running trap from solvent weld pipe and fittings (not quite enough room for an off-the shelf trap), though this would still be connected to a short upstand of pipe with a funnel in the top! However, I'm more concerned about the general arrangement of the pipes as described above and whether it contravenes any regs.
Would be grateful for some advice.
Matt
Matt
