Is there a flexible pipe available that can be used for a condensate run off ?
If so have any of you got links to a supplier for a modest 5m of product ?
The boiler is being replaced in a week and the kitchen isn't due for replacement for a month beyond that. So I'm trying to avoid ripping all the units out straight away via a flexible hose being run as a temp measure. When the units are all out and I have access to the walls a permanent rigid pipe solution could be installed.
