Good evening all,
Been reading a lot on these forums, and thought it would be a good time to register as I would also like to share my input on other things etc.
One question I have is. Why does a condensate pipe have to be a minimum of 32mm ? In 2010 plumber who installed my new boiler installed 22mm condensate pipe outside. He put like some foam lagging on it.
To be fair, it never froze but then again we have not really had harsh winters in London.
This summer, the lagging was tattered and worn to bits. The pipe goes straight into the cast iron pipe and silicone was used to patch it up. I do not think its the right way. Ok so the silicone was leaking every time a toilet was flushed.
So last week I went up there, bought some lagging from Toolstation and cable tied it on as the previous plumber had done. Also removed the previous silicone so it literally had the condensate pipe hanging into the hole in the cast iron. And I used silicone to block the hole, again just like the previous plumber. Now I understand it might not be done properly but for now its a temp fix.
Ideally I want to sort it properly. I cannot plumb the pipe inside to a sink waste as its just too far and awkward.
I have been told 2 things, The pipe should be at least 32mm (im guessing smaller pipes are more likely to freeze) and also apparently the lagging I used was wrong.
So what lagging do I really need ? Also if the pipe from inside is in 22mm. To the point it reaches outside, can I make it into a 32mm ? Im not sure what is needed to scale up a pipe. I am sure there is something for it. Would that be ok though if I did it like that ? If anyone can send me a link to an item I can buy on the web which will be adequate.
And also the pipe that goes straight into the cast iron. Is it right the way it is with silicone ?
Sorry for a long post.
Kind regards
Swifty
Kind regards
Swifty
