Condensate waste pipe slightly larger than 21.5/22mm?!
8 Aug 2006
Middlesbrough
I'm trying to join two pieces of condensate waste pipe from a combi boiler, but it seems like the pipe that has been used is slightly thicker than the 21.5/22mm stuff that's standard.
Hence, I can't seem to find anything that will allow me to join the pieces together - all I want is a straight-through coupler (preferably pushfit). Does anyone have any suggestions, as I'm well and truly stumped!
McAlpine Commpression Coupling they normally fit anything but on some boilers I have used a Wasshing machine flexible waste extension, the rubber push fit normally fits the condensate spiggot (Especially Remeha)
I then fit a washing machine waste upstand to take the condensate to drain (which is OK if you have the room to do it!) :wink:
by far the easiest way to do this, trying to find a match for overflow pipe is trickier than any other pipes, it can be a nightmare and usually means ripping one half right out,
Thanks for the advice - any idea where I might be able to pick up a McApline 22mm compression coupling? I haven't seen anything like that anywhere I've looked, only the standard ones for 32mm and 40mm pipes.
Any 'proper' plumbers merchants will have them, feel free to join the queue on a Saturday morning to ask for them though.
DH
They all seem to be on godforsaken trading estates, with only a burger van for company.....
It could be Marley overflow :evil: poxy b`stard sized stuff - but you can get adapters for it :wink:
Heat one end of the overflow with an electric paint stripper like a high powered hair dryer then carefully push the other end into the heated pipe to form a socket when cool twist to remove & solvent weld in place job done
For the benefit of anyone who might come across this thread in future with a similar problem, the adapter I needed was a McAlpine R1M. I had a bugger of a job getting hold of one (none of the plumbers' merchants near me had one in stock), but it did the job perfectly.
