I have an issue with an in line extractor fan setup that runs from my bathroom ceiling through the loft to an outside vent on the soffit. The hose is a 100mm flexible one that runs about 2 metres from the bathroom ceiling to the fan and then about another 6 meters to the outside vent.
I only noticed a problem when the fan which is screwed to a joist stopped working and on investigation I found that the flexi hose had dipped into the gap between the joists either side of the fan and had filled up with water to such an extent that the water had flooded the fan and has probably shorted the fan out. In addition the problem is repeated along the entire length of hose as it runs across the joists and dips down resulting in water build up.
I think there are two issues:
• The flexi hose isn't level and unless supported along its entire length there will always be a build up in the dips - I could support it all the way along using some chipboard flooring but could I solve this with a proper 100mm plastic pipe? As long as it is level or even sloped towards the outside vent would this be an ok?
• On inspection the fan installed was the cheapest 100mm you can get and reading up on the net I have see that this only works up to 3m of hose and the fan simply isn't powerful enough to extract the moist air along the entire length of hose -
If I upgraded the fan to any one of the decent ones available online or in screwfix etc would this be powerful enough to push the moist air to the outside vent? If I upgraded the fan would this enable me to keep the flexi hose (I would support it to ensure no dips).
Also the 2m run of hose from the bathroom to the fan runs slightly up hill as it has to go over a joist. There is nothing I can do about this as it isn't accessible so would a more powerful fan stop the build up of water in this section?
Any advice appreciated?
p.s. when I first found the problem I tipped the pipe up to see the issue and the cold manky water ran back down the pipe to the bathroom vent and poured through onto my daughter having a bath. She was not impressed.....
