@Vatt
Just stumbled across your post regarding the dripping from your (then) new condensing boiler... I have a very similar problem, i.e. newly fitted condensing boiler, excessive dripping from second pipe into the communal corridor etc.
I seem to be the only one on my floor with a condensing boiler so I can't compare what others have done to deal with the water puddles.
At this point nobody has complained about it because I have put a little jar underneath it which catches the water. However, that means I have to empty it mornings and evenings at the moment...
Unfortunately my plumber can't fit this pipe into a waste pipe inside the flat as the boiler sits across the corridor from it, so I feel a bit stuck with this dripping pipe issue outside my front door.
How did you solve it in the end? All I can think of is putting a big flower pot outside my front door and underneath the pipe in order to catch the water - not an ideal solution really...
Any suggestions would be greatly appreciated.
