After searching google I see they are sold by Amazon and many others so I guess the answer is - Yes.
That they are sold by or through Amazon, eBay etc, is no guarantee that they are legal, or safe, or that any compliance/certification/standards claimed for them are not false.
Also, what are the recommendations/guidelines about mains voltage downlights in a bathroom.
Mine would be don't use them, irrespective of voltage.
Recessed lighting can be OK, but only in large sizes.
The little 2" diameter ones came out of the retail display market, where they were originally appropriated from semi-professional film projectors designed to throw a narrow beam of light onto a screen and were used to throw small pools of light onto individual items. Ever noticed how a common term for them is
spotlights?
They are actually specifically designed to
not be any good for providing general room illumination.
I sometimes refer to them as torches, and if you look at the business end of a Maglite you'll see a marked similarity to an MR16 lamp. Fiddling with the lamp technology does nothing to address the problems of the format.
In places like kitchens, bathrooms, WCs, possibly hallways and landings where you just want unobtrusive efficient lighting that just gets on and does the job, something like this is ideal:
Fluourescent lights can be dimmed. If you find one you like which isn't dimmable, look to see how easy it would be to replace the ballast with a dimmable one (which you can often find on fleaBay).
If you want LED, again there are larger sizes, e.g. the Thorn BaseLED.
http://www.thornlighting.co.uk/download/Base_LED_Brochure.pdf
http://www.thornlighting.co.uk/PDB/Ressource/teaser/E2/TLG_BaseLED.pdf
http://www.thornlighting.co.uk/object/PDF/datasheet.aspx?CompanyID=7&GroupID=12650&CL=E2&CC=GB
And quite a few people now sell LED panels, in varying sizes, but you'd need to check about suitability for bathrooms.
//www.diynot.com/wiki/electrics:bathroom-zones
Also, with all recessed lighting in bathrooms you need to make sure that warm moist air can't get through the ceiling, particularly if there's a loft above. Being IP rated means that water can't get to the electrical connections, doesn't necessarily mean that there's no path through or around the light for air.
