My taps came with female 1/2 connector. I didn't really know how to connect this to my pipe, so I bought a female to male adapter with a compression joint on one end. I wrapped the threads in PTFE, and have no leaks from this joint.
However this is brass and I'm trying to connect it to my push fit system plastic PEX pipe. I put in a pipe insert into the plastic pipe, hooked it up, tightened the compression fitting as usual, but it just won't seal and has a tiny drip.
Any advice on how to seal this or advice on an alternative fitting I can use.
