I'm fitting a new sink with a monobloc tap. The monobloc connectors are 10mm where they screw into the tap but the other end are female tap connectors i.e. I could connect a tap to them.
I expected a compression connection at the supply end.
Should I look for a joint to connect my monoblocs to the supply pipe or should I buy some new monobloc connectors with a compression fitting at the supply pipe end?![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
