    Dismiss Notice
Connect Wireless Texecom devices to power supply?
Discussion in 'Alarms, CCTV & Telephones' started by skyhawker, 20 Mar 2018.
  1. skyhawker
    skyhawker
    3 Jan 2015
    237
    Thanks Received:
    London
    Country:
    I know sounds like paradox, but say I have cables run from alarm panel to location of where I would like ane extra PIR. Lets say I have run out of hardwired zones so I want to add the zone with Ricothet, can I use the alarm cable to power the device so I do not need to worry about flat batteries?
  2. Sponsored Links
  3. bernardgreen
    bernardgreen
    3 Nov 2006
    25,129
    Thanks Received:
    2,479
    Bedfordshire
    Country:
    Yes you could providing the supply voltage is correct and the supply is smooth DC and not an electricallly noisey supply such as that which many switch mode power supplies produce.
    That said connecting long leads to the battery terminals of a radio transmitter designed to operate on batteries may have an adverse effect on the transmitter's ERP ( effective radiated power ) and stability. This may reduce the maximum distance over which the device will work reliably.
    Remote powering may invalidate the device's type approval for use on Licence Exempt frequencies.
  4. sparkymarka
    sparkymarka
    16 Feb 2011
    8,629
    Thanks Received:
    1,313
    Sheffield
    Country:
    No .....
    Don't listen to Bernard ....
    Would be cheaper to fit an extra expander ..
  5. bernardgreen
    bernardgreen
    3 Nov 2006
    25,129
    Thanks Received:
    2,479
    Bedfordshire
    Country:
    I was suggesting it was NOT a good idea and gave two reasons, You said No so are we not in agreement not to do it.
  6. aptsys
    aptsys
    16 Sep 2007
    1,836
    Thanks Received:
    146
    Country:
    It was a perfectly valid reply.
    However, it is of course definitely possible to externally power these devices
  7. sparkymarka
    sparkymarka
    16 Feb 2011
    8,629
    Thanks Received:
    1,313
    Sheffield
    Country:
    The hardware needed to convert 12v to 3v is not cost effective and would be classed as a bodge !
  8. secureiam
    secureiam
    20 Jun 2014
    5,217
    Thanks Received:
    642
    Lancashire
    Country:
    well how many zones do you have free?
    yes it can be done, but as already pointed out it shouldn't be attempted for various reasons.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
