I have now got my panel upgraded to 3.02 and was checking through the rest of the setup, and realised that the panel info on the ios app is showing between 650 and 850mamps and flashing yellow. Downloading the ENCalculator it does appear that I am at the limit of the power on the panel.
I have 2 LCDLP keypads, odyssey bell, soundbomb, Ricochet expander and comip with 9 PIRs (mix of petwise and quad) and the Texecom external PIR.
Whats the best option here? Should I install another supply? I have seen Elmdene do some, but I wont be able to fit it next to the panel, will be in the next cupboard.
but then does that mean I need to run a power cable between the new boxed supply to the alarm panel and connect that up to the various devices. ie a PIR has 2 cores connected to the panel zone connections and 2 to the external power supply? That will make my somewhat neat install a mess!
Also the Aux 12v fuse is flashing intermittently on the diagnostics screen in wintex.
Cheers
Cheers
