connecting 40mm waste into stack, next to WC waste
10 Nov 2010
Kent
Quick question: I have a Stack with the WC waste coming in on the left and would like to bring the shower and basin (as one) at the front, there is a cut out for this but its at the same height as the swept WC - is this ok according to regulations? Thanks
Is the cut-out you mention on the side of a junction/tee piece?
Most plastic soil pipe manufacturers make junctions with boss upstands on the side for the purpose you require.
Yours sounds like one.
no problem with that being the same height its not in the none permitted area for crossover.
if you are fitting it to the front of the stack crossover regs don't come into it.
